October 4, 2011, 03:45 |
intersection of meshes in centrifugal pump
ali
Rep Power: 15 |
hi everybody
i want to import 2 meshes of a complete pump, impeller mesh(rotating part)and casing(stationary part) but when i import 2 meshes and i want to create the frozen rotor interface between them,meshes have an small overlap region i mean the two side of interface is not connect to each other in this case i think i should use the intersection option in interface window in cfx.now my question is : what is the best model of intersection for my case? what happen if i dont use intersection? thank you |
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop | olivier | OpenFOAM | 8 | October 29, 2018 07:49 |
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance | barak182 | ANSYS Meshing & Geometry | 2 | August 18, 2010 03:07 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
centrifugal pump and centrifugal fan | Mangesh | Main CFD Forum | 3 | January 3, 2006 11:21 |
stator-rotor interaction in the centrifugal pump | G.H.Lee | Main CFD Forum | 4 | May 25, 1999 07:33 |
