October 4, 2011, 09:16 |
Regading importing surface mesh in cfx
Arun raj.S
Rep Power: 14 |
Hi all,
I am not able to import surface mesh in cfx 12.. Is it possible to import surface mesh (which is created using Icem cfd) in any other version of cfx ?.. |
October 4, 2011, 17:39 |
Rep Power: 143 |
No versions of CFX support 2D meshes, ie surface meshes.
Some versions of CFX automatically extrude a 2D planar mesh one element thick but that might only be for the Fluent mesh import option. |
October 4, 2011, 18:21 |
soni
Rep Power: 14 |
Can anyone tell me how can I rerun a file in CFX?I simulated a turbine for .000125 timestep. Do I have to run from initial values??How can I run from last timestep? Thanks |
October 5, 2011, 00:51 |
Arun raj.S
Rep Power: 14 |
Hi Glenn,
I heard Version 13 can do ... not possible in 13 also? |
October 5, 2011, 03:47 |
D
Rep Power: 15 |
@ Soni : You can run from previous result file (the one with old timestep) as initial file. But is this exactly what you want to do ? or you want to see the effect of time step size on result ?
-Dinesh |
October 5, 2011, 06:33 |
Rep Power: 143 |
Soni - please do not hijack threads. Start a new thread for your question.
CFX does not support 2D simulations, so does not support surface meshes. Or are you asking about immersed solids? |
October 5, 2011, 15:36 |
soni
Rep Power: 14 |
I am so sorry Gorrocks!!
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
Error when importing mesh into CFX! | Faraaz | CFX | 5 | May 17, 2009 03:13 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
