Convergence problem with axial pump simulation! |
October 4, 2011, 15:35 |
Hello, everyone,
now I am suffering a convergence problem with my simulation of axial pump. In my case, only one blade section is simulated, and mass flow rate BC is used in the inlet, zero pressure is used in the outlet. But I am not quite sure about the physical timescale. Now I am using 1/ω as the timescale as suggested in the tutorial. Actually I have ever used a larger value, e.g. 2π/ω when the convergence was not achieved with 1/ω, but this change was not helpful. So here I am asking you guys who can recommend me a better solution. I even noticed here that somebody mentioned "residence time". Is it the time for the water to flow through the whole domain? Is it suitable for the simulation with a long inlet pipe and a long outlet pipe? Does anybody here have a similar experience? Thank you for your attention! |
October 4, 2011, 17:43 |
Rep Power: 143 |
The timescales are just guides to start from. If that is not converging then use a smaller time step and forget about physical significance.
October 5, 2011, 04:23 |
D
Rep Power: 15 |
Try Automatic timescales
Problem with centrifugal pump calculation | Michiel | Main CFD Forum | 2 | June 17, 2012 21:32 |
Axial fan simulation in UG/NX 7.5 | fan123 | Main CFD Forum | 2 | April 23, 2011 08:22 |
Pump Station Simulation | GUSU | CFX | 6 | October 14, 2009 06:40 |
a problem in pump simulation | feng | CFX | 5 | August 23, 2004 03:21 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 13:43 |
