help how to simulate the velocity in the rotary atomizer |
October 23, 2011, 09:00 |
GMXiao
Rep Power: 14 |
,I have a rotary atomizer whell (disc atomizer) with 36 channels and 5500rpm, I want to calculate the volecity in the outlet of the disc(the tip of the channels).
I used the mutilphase molde(air and water,standard freesurface model,homogenous model),3d rotary domain(just including the channel in the disc),steady flow in CFX, but the result is so different from the result by exprience fomula, it is much large(about 40% of the radial velocity). If I just want to calculate the velocity in the tips of the channels ,does this model have any fetal error? If have,what is it? Then I want to calculate the diameter of the droplets and it's distribution near the channels,what should I do? If I add a stationary annual domain (water-air domain)outside the rotary domain to simulate the air outside the atomizer,is it right? |
October 23, 2011, 17:03 |
Rep Power: 143 |
Can you show a drawing of the device and more description of how it works. I have no experience in rotary atomisers.
October 23, 2011, 23:32 |
GMXiao
Rep Power: 14 |
i do not kown how to handout a picture in this forum, it is just a plain rotary atomizer with 36 channels , and 5500rpm, it's diameter is 420mm ,can you give me your email ?
October 24, 2011, 00:28 |
Rep Power: 143 |
I do not give my email out on the forum.
Post a message, click "go advanced" then attach the image. |
October 24, 2011, 01:26 |
the drawing
GMXiao
Rep Power: 14 |
rotary atomizer 5500rmp the max diameter is 420mm, the liquid is water , the pic is in the attchement, ,my model just include the flow domain (the empty partion of the wheel,from the center to the tips of the channels) thank you
October 24, 2011, 01:31 |
Rep Power: 143 |
You say it is steady state. Do you know it is steady state? There is a good chance that on the fluid time scales this flow is transient. You need to keep your mind open to this being transient.
You might be able to get a good estimate of the flow rate through this thing with careful simulation. Simulating the droplet generation in this device would be next to impossible in any CFD code. What are you trying to learn with your model? |
October 24, 2011, 02:20 |
GMXiao
Rep Power: 14 |
thank you for your advice. I will try it later with transiant model. you said ''Simulating the droplet generation in this device would be next to impossible in any CFD code" Are you sure? What a pity. My boss demand it , as you know, only result ,no process and reason.
appreciate for you help and best wishes for you . |
October 24, 2011, 05:28 |
#8 | |
Rep Power: 143 |
Have a look in the CFX documentation and literature about primary and secondary droplet breakup. When you understand all that you will see why your task is just about impossible. But as I said you might be able to get the flow rate about right. Maybe that will be a good start. |
Display Modes | |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 19:08 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 08:42 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 04:26 |
Settling Velocity - FLUENT Discrete Phase Model | Lily | FLUENT | 2 | March 6, 2002 21:44 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
