Total Energy and a Stage Interface
Old   November 16, 2011, 12:22
Exclamation Total Energy and a Stage Interface
aerost is on a distinguished road
I am trying to solve a rotor stator problem using the total energy heat transfer model (incl. viscous work). I have a GGI stage interface between the single peridodic rotor and the single periodic stator (pitch ratio 5:7). When I converge this solution though I find that there are very large but highly localized temperature gradients in the flow right at the stage interface. The rest of the domain is pretty close to isothermal, but there are 200+ degree F gradients at the interface. Total pressure is very constant and smooth over this area though.
Looking at the monitors, all of the mass and momentum residuals converge very well, but the Energy residual seems to flat line at ~2e-3...
Would adding a pressure profile decay help this at all? Is there any way to add a "Temperature profile decay" of some sort? I think it might help the solution converge. Any other ideas?
Thnanks.
aerost is offline   Reply With Quote
Old   November 16, 2011, 18:51
Do not activate the viscous work model unless it will significantly contribute to the result. No point in activating unnecessary models.
This FAQ should give you some tips for getting it to converge:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
stage interface, temperature gradient, total energy
total energy and mass balances megacrout OpenFOAM 3 October 20, 2011 09:09
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
diff bet total energy model and thermal energy model?? vijeshjoshi23 Main CFD Forum 0 October 8, 2009 02:29
What is the total energy for incompressible fluid? Harry Dong Main CFD Forum 12 February 4, 2006 00:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
