November 8, 2011, 09:47 |
2.5D simulation in CFX-pre
@p N
Rep Power: 16 |
Hi All, Im carrying out 2.5D simulation of centrifugal pump.The following is the procedure Ive used to make the geometry
There is a problem in the way CFX is calculating inlet and outlet areas. It is calculating the areas exactly an order of magnitude less than actual because of which the velocities calculated are an order of magnitude more; this results in a highly unrealistic value of pressure being calculated. Is there a way to rectify this problem? I checked out if I could write a CEL, but seems, CEL is just for post processing and for extracting calculated quantities. Can anybody throw some light on this? |
November 8, 2011, 16:45 |
Rep Power: 143 |
You have either a geometry/mesh problem which is making the faces too big or small, or you are scaling them in CFX-Pre.
You should always check the scale of the model is correct in CFX-Pre before proceeding. |
November 9, 2011, 04:01 |
@p N
Rep Power: 16 |
Thanks for you reply. The point to be noted is, as its a 2.5D model, Im having curves instead of surfaces, so in essence CFX instead of calculating surface areas is calculating curve length (I suppose) multiplied by the one layer thickness in z-direction. Im attaching the 2D geometry. Please note that instead of outlet face Im having a 'line' and instead of inlet face Im having a 'curve'
November 9, 2011, 05:18 |
Rep Power: 143 |
Well, that will be your problem then. The flow rate is calculated over the one element thickness which is likely to be tiny. And I am guessing you assumed that would match the full geometry? So you need to convert the flow rates into flow per unit length.
November 10, 2011, 01:01 |
@p N
Rep Power: 16 |
Ok Thanks Glenn, youve got me thinking.. Ill think on those lines. I was considering the full flowrate
November 10, 2011, 04:34 |
Rep Power: 143 |
Many others have made that mistake. You are not the first.
When CFX finally introduce a proper 2D solver the problem will be fixed. |
2.5d simulation, centrifugal pump, cfx-pre, icemcfd |
Display Modes | |
Setting Pressure Boundary Conditions in ANSYS CFX Pre | saisanthoshm88 | CFX | 21 | February 22, 2017 16:50 |
Under-relaxation for steady state simulation in CFX | Chander | CFX | 7 | May 1, 2014 12:44 |
nucleate boiling simulation in CFX | Anil | CFX | 3 | August 25, 2010 14:18 |
Initial Values for Trasient simulation with CFX | shaban | CFX | 1 | April 30, 2010 06:25 |
CFX simulation file bank | eslam | CFX | 2 | June 15, 2007 07:46 |
