Fluid Solid Interaction
Old   November 30, 2011, 18:49
Question Fluid Solid Interaction
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Hi all
I got the following error while doing FSI simulation inside a straight tube.
A negative ELEMENT volume has been detected. This is a fatal error and execution will be terminated
Does inappropriate boundary condition result in this error? If not, what the problem is. I used a time dependent velocity distribution at inlet.
Thank you
Regards,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   December 2, 2011, 07:52
Zigainer is on a distinguished road
Negative element volume is probably a mesh problem, so first check your mesh.
Zigainer is offline   Reply With Quote
Old   December 2, 2011, 11:37
omid
omidiut is on a distinguished road
When your deformation in solid domain is large, this error always be occur. One of the limitation of FSI simulation is it. you most use smaller time step.
omidiut is offline   Reply With Quote
Old   December 12, 2011, 06:37
JIM
qingyue1987 is on a distinguished road
YEAH,i also encounter the same problem. I learn to use the rigid body .but if the force was applied the mesh motion will destroy the elements....how to solve the problem? are there someone know how to use the rigid body and how to write the formula or CEL for it?
qingyue1987 is offline   Reply With Quote
Old   December 13, 2011, 03:14
omid
rigid body solution is different from FSI solution.cloud you explain more?
Old   December 13, 2011, 03:18
JIM
you know ,rigid body is another type of simulation of FSI,
Old   December 15, 2011, 06:31
k_k
Kailash
k_k is on a distinguished road
Increase the mesh stiffness near smaller elements or where you have folder mesh. Use a smaller time step.
k_k is offline   Reply With Quote
Old   December 15, 2011, 06:35
JIM
how to use ''transiant analysis''and 'steady state analysis' in FSI ?
Help needed in meshing for Solid to Fluid Heat Transfer niazaliahmed FLUENT 2 February 22, 2020 15:47
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? acro CFX 15 September 23, 2016 11:16
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Chemical interaction between solid and fluid rock FLUENT 3 March 31, 2010 17:49
coupling solid and fluid cells?? kcg Siemens 4 March 13, 2007 09:39
