December 23, 2011, 10:36 |
IGES import to TurboGrid
Oleg
Rep Power: 14 |
Hi guys.
Is there any way to import blade geometry that is in IGES format (in fact i got it in SolidWorks) into TurboGrid? BR Oleg |
December 24, 2011, 04:35 |
Rep Power: 143 |
You should export from Solidworks in parasolid format. It is a much better format for ANSYS and SW.
December 26, 2011, 06:59 |
Oleg
Rep Power: 14 |
Thanks. But I cant find in help how to get blade from design modeler to turbogrid. When i connect them in workbench and try to update geometry i got error message. What have i done wrong?
December 28, 2011, 21:31 |
Jeff
Rep Power: 15 |
Whoever had setup your licensing didnt make sure geometry modeler was disabled (a requirement for the ANSYS turbosystem). I think there is a setting in the workbench for preferences that lets you disable the geometry one (set from 1 to 0) and make blade editor default, it is in the ansys turbosystem pdf help file.
Also when you get that working there is going to be alot more work to do to get into a turbogrid format from DM. Setup flow paths, export points, flow paths, etc. You might want to try to go through BladeGen if you have it on a windows machine. |
Display Modes | |
[GAMBIT] problem to import iges file | jackr84 | ANSYS Meshing & Geometry | 1 | August 11, 2009 01:16 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
IGES import problem | Kiran | Siemens | 2 | September 10, 2006 14:18 |
IGES on turbogrid | clo | CFX | 3 | May 23, 2006 04:35 |
import geometry in IGES format | salvatore | Siemens | 2 | July 6, 2001 06:07 |
