How To save a created mesh file in Ansys Meshing
Like Tree1Likes
  • 1 Post By NickFL
Old   November 4, 2010, 19:20
Question How To save a created mesh file in Ansys Meshing
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear All
I created a geometry in Ansys Workbench release 12 and then I meshed it in Ansys Meshing. I saved the meshed geometry as *.wbpj, then, I launched CFX-Pre in order to solve my problem but CFX- Pre only import *.cmdb files and I could not save the created mesh file as *.cmdb in Ansys CFX release 12. I am really confused how I should save a created mesh file in Ansys Meshing which can be readable by CFX-Pre.
Thanks in advance
ashtonJ is offline   Reply With Quote
Old   November 5, 2010, 05:49
antonio is on a distinguished road
Hi.
Try to save it as MSH file.
Regards
antonio is offline   Reply With Quote
Old   November 5, 2010, 08:18
NickFL is on a distinguished road
First of all your wbpj is your Workbench file and it basically a list of what files are in the project and where they are. There is a directory with the same name as your wbpj that is the location of all your files. DO NOT MOVE THESE FILES AROUND!!! It could destroy your project.
If you want to take your mesh created in ANSYS meshing into standalone CFX there are several ways to do this. Perhaps the easiest is, in Workbench, to add a CFX component system to your project. Drag the mesh onto the Setup of the new CFX and a blue line will appear between the two. Notice the mesh icon changes from green checkmark to lighting bolt letting you know it needs to be converted to CFX mesh. Right-click on mesh and select Update. Now we need to make a copy of this mesh into the directory where you want to run CFX Standalone. To find this file, select View->Files. A pane opens and find the correct cmdb file. Right-click and select open containing folder. Copy this file into your CFX Standalone working directory. DO NOT MOVE THE ORIGINAL.
jiaji lu likes this.
NickFL is offline   Reply With Quote
Old   November 5, 2010, 10:13
playmaster
playmaster is on a distinguished road
In the outline window of CFX-Pre, right click on (Mesh). select (ANSYS Meshing). find your saved (*.cmdb) file in your drive. enjoy it
playmaster is offline   Reply With Quote
Old   January 7, 2012, 22:04
Hassan Ishtiaque
hishtiaq is on a distinguished road
I'm using Ansys CFX 12.1. After creating the mesh file I am trying to access the mesh file from CFX-Pre but I'm getting the error:
The file from which the mesh is to be imported, "H:/CFD Assignment". does not exist.
Unable to import the requested mesh:
Type ="GtmDirect".
File="H:/CFDAssignment".
Generic options ="".
Specific options ="".
The mesh file that I got after meshing is *.cmdb and I did what you have advised but I'm still getting the same error.
Please help.
hishtiaq is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
