January 31, 2012, 03:46 |
Help needed for my project
Shashwat
Rep Power: 14 |
Dear friend
I am doing flow analysis inside the artery . considering the artery has porous property I setup all the condition . When I give run , I got error. I have attached the output file . Please help me where I did mistake Thank you Regards shashwat |
January 31, 2012, 05:40 |
Rep Power: 143 |
The error message says it all. You have turned extend min/max off on your profile function, but then asked for a value outside the defined profile in your initial condition. So it bombs out with an error. Read the error message carefully.
February 1, 2012, 03:16 |
help needed for my project
#3 | |
Shashwat
Rep Power: 14 |
I also tried two ways. 1.Turned off extend min/max 2. Turned on extended min/max I am trying for the past two days for the transient analysis. I did not get the proper solution Please find my profile(t) and output file please help me to solve the problem thank you regards shashwat |
February 1, 2012, 05:07 |
Rep Power: 143 |
Use a smaller time step.
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Help needed with project race car | richalfa | Main CFD Forum | 0 | August 6, 2010 09:40 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 09:33 |
Project Advice Needed | Kapil | Main CFD Forum | 6 | September 4, 2006 08:00 |
CFD project idea | John Cleveland | Main CFD Forum | 4 | March 8, 2005 12:55 |
