Map external data (heat flux in) on solid face |
January 30, 2012, 16:13 |
Hello!
I want to map radiative heat flux (x,y,z,j_rad) on a certain face F of a solid domain S. I do this using Initialise Profile Data function, and the reason for it is that I have a radiative heat flux distribution on the face F calculated in another sofware. My solid S is totally enclosed by fluid = air. Now: when I map the the external data (Use Profile Data) on the face F, I have a boundary condition defined on F but the Interface between F and fluid domain is lost, i.e. I can not define Interface to model heat transfer from F to air. HOW COULD I SOLVE THIS AND MODEL/DEFINE ALSO INTERFACE? Any ideas, or am I missing something? |
January 30, 2012, 18:22 |
Rep Power: 143 |
Use a heat source term on the interface boundary. Then you have the normal interface between domains, and can add your defined heat flux where ever you like.
January 31, 2012, 14:32 |
Hi Glenn!
Thanks, it works ... guess you can see I am relatively new to CFX Regards, Jerry |
external radiation bc, heat flux, interfaces |
Heat Flux as a Profile Boundary Condition | Hitch8 | CFX | 2 | April 22, 2010 14:09 |
Heterogeneous heat flux | Kev | STAR-CD | 4 | July 7, 2009 05:48 |
heat flux in a solid slab | achauha1 | FLUENT | 1 | June 22, 2009 16:34 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
