Temperature Profile through a fluid solid interface |
January 31, 2012, 02:16 |
Hi
I have simulated a heat transfer problem with two solid domains on the sides and a air domain in the middle (using two fluid solid interfaces)- for different mesh sizes As i understand the hybrid value of Temperature gives the temperature at interface. Conservative temperature plot shows a plot staring at a lesser temperature(as we wud expect) But I need to plot a temperature profile for a line running through all the domains (continuous). Hybrid value plot is quite different (with large gradient variation) pl. do help asap |
January 31, 2012, 05:42 |
Rep Power: 143 |
You have to understand what hybrid and conservative actually mean before deciding this. Conservative is the value of the control volumes. Hybrid uses the wall value at the wall.
In general in this case I would use conservative as it shows the control volume values, and that is what the solver is using. |
January 31, 2012, 06:03 |
Thanks Glen
Just thought if i can reproduce the (nice smooth)temperature profile (starting from wall to core region ) as shown in books. I understand Hybrid are wall values n conservative values are that of control volumes. but the plot function in CFDpost either chose hybrid or conservative to plot. |
January 31, 2012, 18:49 |
Rep Power: 143 |
And a fine mesh is another requirement to get a nice smooth profile.
January 31, 2012, 22:23 |
Oh.
Thank u |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 32 | February 3, 2021 03:37 |
solidWallHeatFluxTemperature at the solid solid interface in chtMultiRegionSimpleFoam | maddalena | OpenFOAM Running, Solving & CFD | 43 | January 11, 2011 02:39 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
