irregular flow
Old   February 6, 2012, 05:58
Default irregular flow
albert
pato is on a distinguished road
hi,
i´m modeling a flow in a channel going upwards through a porous media(1cm thick), instead of doing it throug the perforated plate. The velocity profile i get at the beginning of the channel is very discontinuous, being negative and positive, and very irregular.
Could someone help me to find a solution in order to reduce this irregularities and have only positive upwards flow?
Thanks!
pato is offline   Reply With Quote
Old   February 6, 2012, 19:10
Are you sure you have adequately converged?
Old   February 7, 2012, 03:04
albert
actuially i had to stop the simulation since they were very long. Nevertheless the masas and momentum were not changing anymore. What parameter should i change to make it converge?
Old   February 7, 2012, 03:14
Anonymous
rideway is on a distinguished road
I dont know if it is your mistake, but last week i was facing a similar problem and the (stupid) mistake was that i wasnt using double precision. If not, try to refine the mesh. Also check that the bouyancy is properly defined if you used it.
rideway is offline   Reply With Quote
Old   February 7, 2012, 04:37
albert
what do you mean with double precision?
Old   February 7, 2012, 05:04
Anonymous
I meant that in the Solver Manager (called Solution in Workbench) you can choose which precision you want to use, Run priority and other stuff.
When you open the Solver Manager, in the Define Run window, there are two folders: Solver and Interpolator. I marked the Double Precision Override in both of them and then I had no problems anymore.
irregular flow
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
