December 22, 2010, 21:10 |
Ansys 12 error
vetriselvan
Rep Power: 16 |
Hi everyone,
I am a new user for this forum.I'd like to contribute and learn from the good work all of you are doing... Coming to my problem, I've installed ansys 12 in my windows 7 and it was working fine for about a week. After that when I try to open workbench, there is a fatal error displayed. Could anyone please suggest a solution for this?...Thanks in advance... [IMG]file:///C:/Users/vetri/AppData/Local/Temp/moz-screenshot.png[/IMG] |
December 23, 2010, 05:32 |
Rep Power: 16 |
Hi.
I must say that I have never saw this error...however are you sure that ansys 12.0 is supported by windows 7? Best Regards |
December 26, 2010, 09:37 |
will try in ubuntu
#3 | |
vetriselvan
Rep Power: 16 |
thanks for the reply... One of my friends is using ansys 12 in windows without error...I tried for reinstalling too.... but negative results...I'll try it ubuntu linux using virtualbox emulator and let you know of the result.... thank you again... |
January 3, 2011, 06:13 |
Kamlesh
Rep Power: 16 |
Hi, Ansys 12.0 working in windows 7 fine.
January 3, 2011, 08:14 |
vetriselvan
Rep Power: 16 |
hi kh_thkor... thanks for the info...
as posted earlier for me also it was working fine and one of my friends working with it very well with out any prob in windows 7.... might be a hardware problem???(you could refer to the error message in the starting thread)... anyway i'm half way through installing it in linux virtual box... |
April 25, 2011, 03:20 |
installation Successful....
#6 | |
vetriselvan
Rep Power: 16 |
after lot of struggling I've installed Ansys 12 in Ubuntu using Virtual box software. We need to install virtual box add ons from web for successful integration of W 7 in Ubuntu. Thats were I struck for long time. Now the software is working fine.... Thanks a lot for all your info..... with regards vetri |
December 22, 2011, 07:28 |
IRFAN HILMI
hi...im new here.. I've tried to install ansys 12.1 on windows 7... but when I open the workbench, fatal error occur... anyone can please help me?...
December 22, 2011, 19:52 |
Hareesh R Iyer
Rep Power: 15 |
@ Epunk & all who have experienced problems with ANSYS 12.0 or higher in Windows 7.
The first thing u must know is that Windows 7 supports ANSYS 12.0 or higher 100%. I've been using v12.0 ever since I got hold of it & is still working without a single crash. I even run multiple ANSYS windows for various analyzes simultaneously. Whenever u install any version of ANSYS, make sure u install all the essential prerequisites prior to commencement of the software installation. Another thing is, if u are not at all sure of handling multiple software that run in FlexLM, don't install more than 1 (eg. ANSYS & Hyperworks together may not work some times). Once installed ANSYS, pl make sure before u start doing analyzes with it, that all de tool platforms like Workbench, Mechanical APDL etc are working. U can run all these from the ANSYS Mechanical Product Launcher. Installing this in Windows is better than any other OS in my opinion. Also prefer installing in non-OS drive of the system if using Windows 7. |
December 24, 2011, 09:06 |
#9 |
IRFAN HILMI
thanks... problem solved... I've uninstall ansys 12, clear all related files and delete all related files in environmental variable.... then reinstall ansys 12... now it working well...
March 17, 2013, 08:56 |
Ansys mechanical APDL launcher error
#10 |
prashant kumar
i've installed ansys 14 in my windows 8 laptop.... i am getting this error continuously.... tried almost everything to sort it out but so far i am unable to solve this puzzle...
Ansys mechanical APDL launcher error... can't create directory : "c:/documents and settings/ReleaseEngineer.MACROVISION/Application Data" permisson denied plz help |
March 17, 2013, 09:14 |
#11 | |
Hareesh R Iyer
Rep Power: 15 |
Dear prshnt09, Why would you want to install Ansys in Windows 8? anyways, try installing as administrator and not the local user. If it doesn't work, downgrade your system to Windows 7 and then install. sure it will work in Win7 |
March 17, 2013, 10:33 |
#12 | |
prashant kumar
i have already installed it..... there was no problem with that..... the problem occurs when i try to open Mechanical APDL..... and then above written error appears.... |
ansys 12, error |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
