Nusselt Number - Heat Transfer over a rotating cylinder |
March 6, 2012, 19:53 |
Leandro
Hello guys,
I'm making a CFX simulating that consists on a air flow over a heated rotating cylinder. I would like to know how to obtain the Nusselt Number and also the averagen Nu for this situation over the cylinder. I know I have the wall heat transfer transfer coefficient but I also need to know how to creat a expression for Nu and how to create a graphic for those values of Nu. I want to keep my x axis from 0 to 2 π or 0 to 360º. Thanks you all! |
March 6, 2012, 22:13 |
Erik
Rep Power: 23 |
You can do this by "create new expression" and insert your formula for Nusselt. remember if you use the wall heat tranfer coefficient it will default to using the adjacent temperature not your bulk temperature.
After you have made this expression you can also create another expression for the average Nusselt: areaAve(Nusselt)@cylinder. To create a graphic, you define a new variable that references your Nusselt expression, and you can use this variable in a contour. |
March 7, 2012, 12:33 |
Leandro
thanks erik! But, how can I set the bulk temperature??
March 7, 2012, 17:09 |
Erik
Rep Power: 23 |
I think there is an expert parameter "tBulk for HTC" which you can set to whatever you wish.
December 8, 2015, 13:17 |
nusselt expression
#5 | |
mehran
Rep Power: 10 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 12:11 |
Heat Transfer from a cylinder in cross-flow | Mat W | FLUENT | 8 | October 4, 2007 17:19 |
