Convergence problem in a vertical vessel
Old   March 13, 2012, 18:23
Default Convergence problem in a vertical vessel
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
Dear colleagues, I am having a weird problem in CFX, the main problem is a vertical separator, but if I model it with a symmetry plane it converges.
In the other hand if I model it without a symetry, the convergence problem starts. Attached you will find the residual and the model pictures
The separator has one inlet and two outlets, here I explain the boundaries conditions:
Inlet : flow mass 15 lb/seg
Top outlet: Average static pressure (0 psi)
Bottom outlet: Average static pressure (0.52 psi).
The fluid is gas with constant propierties, K-E for turbulence.
High resolution for Advection scheme and auto timescale.
As yuou can see the case is very simple and I don´t know what is happening.
juliom is offline   Reply With Quote
Old   March 13, 2012, 22:32
This is almost certainly caused by a transient flow starting up, which the symmetry plane prevented. See the FAQ for further details: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   March 14, 2012, 07:36
Julio Mendez
Dear Glenn,
Could you explain a little bit more, because I´ve read this FAQ several time and I don´t find anything new to get convergence in my case.
Thanks before hand
Old   March 14, 2012, 16:21
The FAQ seems clear to me. I would remove the symmetry plane, and try a larger time step. If that does not give convergence then your flow is not steady state and you have to run transient.
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
Convergence problem Praveen FLUENT 0 September 15, 2000 06:34
