BOILING HEAT TRANSFER COEFFICIENT
Old   October 8, 2008, 20:12
Default BOILING HEAT TRANSFER COEFFICIENT
John
Hi, I am a fluent user, however I wonder if there is any tutorial in CFX that could help in the following problem:
I try to find a correlation for the heat transfer coefficient along vertical pipe filled with porous media. The flow enters the pipe as subcooled liquid (at room temperature) and leaves the pipe as superheat.
I really do not care about phase change inside the pipe. The most important for me is the prediction of temperature at the outlet of the pipe and the heat flux along the pipe.
The liquid mixture enters the pipe is a mixture of methanol/water, however I believe that I can use an average peoperties of both liquids.
The heat transfer coefficient should be changing along the pipe according to different phase change regions.
I appreciate any help with refering to papers or an idea about how to do this.
Thank you, John
Old   October 12, 2008, 11:31
Default Re: BOILING HEAT TRANSFER COEFFICIENT *NM*
ergün
Old   April 4, 2012, 08:03
raoudha
raoudha is on a distinguished road
Originally Posted by John
;90295
Thank you, John
hello John
I´m trying to simulate two phase flow of an methanol/water mixture by fluent in vertical tubes, my problem is how to define the materiel properties could you help pleaaaase
thank a lot
raoudha
raoudha is offline   Reply With Quote
Old   April 4, 2012, 17:50
Please post fluent questions on the fluent forum.
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
BOILING HEAT TRANSFER COEFFICIENT John FLUENT 1 September 4, 2013 07:57
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
