April 19, 2012, 12:37 |
Question about interface
I'm studing a microjet propulsor; the engine is formed by a compressor, a combustor, a turbine and his exhaust nozzle. I was thinking if it is possible to make a multidomain simulation with a fraction of the combustor (one sixth) and all the turbine. For now I've only done simulation of the compressor and the turbine alone and a simulation of one sixth of the combustor (to reduce the complexity of the simulation.). I want to compound the one sixth of the combustor with the turbine block; in the attached image I've done it with the stator of the turbine to the one sixth of the combustor, but I don't know which tipe of interface I need to use. I want that the result on the combustor outlet will be duplicated all over the inlet of the turbine like a periodic thing, ie. same temperature pattern, same pressure pattern, same velocity pattern etc. I hope someone can suggests some solution. Thanks in advance |
April 20, 2012, 06:59 |
Thanks for the hint, but if I want to make a steady state simulation (my fault that I don't have specified before) is there some method to have the results obtained from the combustor outlet (one sixth) interfaced with the turbine?
So the sixth of the combustor is the boundary condition placed on the inlet of the turbomachine duplicated six times all over the 360 degree of the turbine mantaining the sixth pattern. I attached a qualitative image to explain better; the combustor is well simulated with a sixth of his entire volume. The left image is the hypothetical temperature pattern on the combustor outlet, I want to place an interface betweet these two domains where this solution will be the turbine inlet boundary condition of all the turbine, simply by placing 5 more identical outlet combustor results. I hope this post is not too complex too understand, sorry for my poor english. Thanks in advance |
the macro of c_face_loop and thread_id of interface | zhang_pioneer | FLUENT | 2 | December 6, 2010 02:37 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
Mesh motion applied to an internal interface | lr103476 | OpenFOAM Running, Solving & CFD | 6 | March 12, 2008 21:07 |
Question about interface flow and adaptive mesh | Luckyluke (Luckyluke) | OpenFOAM Running, Solving & CFD | 31 | June 13, 2007 04:12 |
