Home > Forums > Software User Forums > COMSOL
Compressible Fluid Flow in COMSOL Multiphysics
Old   November 4, 2008, 01:59
Default Compressible Fluid Flow in COMSOL Multiphysics
BBG
Hey all,
I am trying to figure out how to do compressible fluid flow with turbulence in COMSOL to determine the lift and drag coefficients for airfoils. I am able to do so for laminar incompressible flow, but of course these are not the correct results.
So far, I have used the Chem Engineering - Non-Isothermal Flow and Convection and Conduction application modes. The Non-Isothermal Flow mode is using the k-e Turbulence Model.
The non-default subdomain settings for the Non-Isothermal Flow are as follows: a) Dynamic Viscosity is 1.52*10^-5 kg/ms b) Initial Pressure is 23842 Pa c) Streamline diffusion off
The non-default boundary settings for the Non-Isothermal Flow are as follows: a) An inlet, an outlet, and the rest are set to the default logarithmic function wall. b) Non-linear weak constraints are on
For the Convection and Conduction: a) All sides are set to Thermal Insulator b) Thermal conductivity, density, heat capacity are set to certain values. c) Heat source is set to Q = p_time+u*px+v*py d) Temperature is initiated
First off, when I try to solve it it returns with the error "Failed to find a solution:
The relative residual (1.3e-006) is greater than the relative tolerance.
Returned solution has not converged."
What does that mean and how can I fix it?
And finally, the temperature is constant around the cylinder/airfoil, however the temperature and velocity fields are not. Why is this? Shouldn't the temperature be changing?
Thanks for any help you can provide!
Old   November 19, 2008, 15:05
Default Re: Compressible Fluid Flow in COMSOL Multiphysics
Rafaele
I have the same error message. Did you found out? Does someone can help?
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
Is recirculating flow is free vortex or forced vortex? FluidKo Main CFD Forum 11 July 21, 2022 07:21
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
