Home > Forums > Software User Forums > CONVERGE
converge compression ratio
Old   July 4, 2017, 18:25
Default converge compression ratio
xinkai liu
liuadam67 is on a distinguished road
why when I want to move the piston toward compression ratio the piston moves very ridiculous, by the way, I already make the cylinder close
liuadam67 is offline   Reply With Quote
Old   July 5, 2017, 02:36
Tobias
MFGT is on a distinguished road
Please define "ridiculous".
Do you have specified the correct piston moving direction?
MFGT is offline   Reply With Quote
Old   July 5, 2017, 06:52
xinkai liu
I have set the piston move as z direction, ridiculous means that when it moves it will over the head or go down a lot. the compress ratio is always stuck in 3 my target compression ratio is set at 10, do I need to set the TDC first and if so how can I set the TDC position.
many thanks
Old   July 5, 2017, 07:55
Tobias
The Piston has to be in BDC position, while the Valves are in closed position.
The minimum Lift (0.2 or 0.1 mm) causes a slightly higher compression ratio as originally defined in CAD.
Do you have selected the correct boundaries that form the combustion chamber?
Old   July 5, 2017, 08:57
xinkai liu
I think I have set the correct boundary, but the compression ratio is still only 3 I don't know why, have you meet this kind problem before?
Old   July 5, 2017, 10:26
Tobias
No, i never had this problem.
Do you have correct units for bore and stroke in the engine.in file?
Old   July 5, 2017, 10:46
Blanco
Blanco is on a distinguished road
I would also suggesto to check che model dimension: try to measure the cylinder diameter to double check you're working with your desired units
Blanco is offline   Reply With Quote
Old   July 5, 2017, 11:09
xinkai liu
after I check the diameter it works, thank you guys, many thanks
compression ratio, converge cfd
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
converge compression ratio liuadam67 Main CFD Forum 0 July 4, 2017 18:22
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
