Home > Forums > Software User Forums > CONVERGE
Steady state monitor does not stop simulation
Old   May 25, 2021, 15:38
Default Steady state monitor does not stop simulation
Adnan
ad1314 is on a distinguished road
Hello everyone!
I just started with convergeCFD. To get familiar with the package i am running a laminar flow simulation through a tapered pipe. I ran a steady case at first and the result converges after a few cycles. As a steady state monitor i set up the mass flow rate through the outlet. i have no grid scaling in the simulation, so converge should stop the simulation when the variation of the mass flow rate is within defined tolerances. But is seems like i making some kind of error and the simulation runs up to the last cycle even though the mass flow rate flattens after a few cycles (See picture). I have attached pictures of the monitor setup window, its input file and the mass flow rate plot form output file.
In addition i have tried changing the tolerance type to absolute, and running the simulation for longer cycles but the result was same. Thanks for your help.
regards
ad1314 is offline   Reply With Quote
Old   May 25, 2021, 16:15
Vigneshwar Ravisankar
rvigneshwar is on a distinguished road
Originally Posted by ad1314 View Post
Hello everyone!
regards
Hi Adnan,
I received your email will communicate to you in email.
rvigneshwar is offline   Reply With Quote
steady flow
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Time marching transient simulation towards steady state to get cl and cd NonStopEagle FLUENT 0 January 12, 2020 06:18
Steady state Frozen Rotor Simulation with different RPM AS_Aero CFX 11 October 10, 2018 03:29
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Under-relaxation for steady state simulation in CFX Chander CFX 7 May 1, 2014 12:44
