Home > Forums > Mesh Generation & Pre-Processing Software > enGrid
Solidworks assembly to enGrid
Old   November 7, 2013, 13:56
Default Solidworks assembly to enGrid
ON
j_j_d is on a distinguished road
I tried to import an STL file of a Solidworks assembly into enGrid for meshing.
When I first started to import, pieces were missing from the original assembly, but after I fooled around with the 'save as' options, I was able to upload the entire assemble.
The current problem I am having is that now enGrid sees the assembly as one solid part, and not different parts as part of an assembly.
can anyone help me?
j_j_d is offline   Reply With Quote
Old   November 9, 2013, 11:37
Retired Super Moderator
Bruno Santos
Greetings j_j_d and welcome to the forum!
There are 2 possibilities that come to mind:
  1. Rely on Blender:
    1. Export each part as a separate STL;
    2. Then import each part onto Blender;
    3. Do any changes that might be necessary, while on Blender;
    4. Then export to enGrid.
  2. Manually reassign the surfaces, as explained here: https://github.com/enGits/engrid/wik...ary-conditions
Best regards,
Bruno
Old   November 15, 2013, 12:49
ON
Thank you very much for your help! I will try those suggestions thank you.
mesh, solidworks, stl format
enGrid Surface grid parameters Claudio enGrid 5 April 29, 2015 03:32
Importing Solidworks Assembly rmc CFX 3 September 30, 2014 10:34
Importing Rhinoceros 3d model to SolidWorks george85 FloEFD, FloWorks & FloTHERM 21 March 5, 2014 05:19
[DesignModeler] Importing Solidworks body (incl parameters) into DesignModeler Evona ANSYS Meshing & Geometry 0 April 14, 2013 08:01
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 03:13
