Ensight - Hide coupled cells in transparency mode |
January 15, 2009, 05:11 |
Dear Users,
I'm using Ensight Gold Version 8.2 to visualize my results from a StarCD Simulation. The mesh contains some so called couples. Everything works fine in Ensight, but when I use the Transparency mode (opaqueness ~ 30) you see these nasty coupled cells of the mesh. Link Does anyone know how can I hide these cells in the transparency mode? Thanks a lot for your answers Best regards Benni link to the image: http://image-upload.de/image/1phDA0/0596c329d1.jpg |
January 15, 2009, 07:21 |
Re: Ensight - Hide coupled cells in transparency m
Create shells on the surfaces and use a set file for exporting to ensight.
The export looks something like: system rm case.set evfi conn trfi conn trload,, c cset news type 3 cset add type 7 cset add type 8 setwrite ,case.set, FLUID1 cset news type 5 setwrite ,case.set, Fluid2 cset news type 2 setwrite ,case.set, Fluid3 cset news type 10 setwrite , case.set , shell_part1 cset news type 16 setwrite , case.set , shell_part2 cset news flui store first direction,write ensi,root,ENSI ensi,form,bina ensi,all,cavg, case.set ensi,done The shells have to be after the fluid cells in the set file. |
Display Modes | |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
