January 10, 2021, 11:09 |
Easiest Import Format? (Python)
Rep Power: 12 |
I have DNS data (from an in-house code) that I would like to import into Ansys EnSight for visualization, and to check some properties.
In the past, I have imported results from in-house codes into Hyperview by writing a Python script delivering the same format as a traditional simulation file. However, I no longer have access to Hyperview, and the formats I used are not compatible with EnSight. Which format accepted by EnSight would be the easiest to follow in a Python script? Thanks in advance, |
February 4, 2021, 14:28 |
Joern Beilke
Rep Power: 20 |
"EnSight gold" format works perfect and is not too complicated.
February 4, 2021, 14:59 |
Rep Power: 12 |
Hi JBeilke, thank you for your feedback, I will try using the format you mentioned.
I had been using Paraview lately |
February 4, 2021, 16:01 |
Joern Beilke
Rep Power: 20 |
Ensight Gold works also very well with Paraview. There is also a binary form, which loads much faster.
There is also a tool called "ens_checker", which tells you if there are problems with your format. |
Why can't I import data in csv format? | liaoyun0126 | FLOW-3D | 1 | June 4, 2022 16:03 |
[ICEM] import model always pending | pulplus | ANSYS Meshing & Geometry | 1 | July 1, 2020 03:49 |
[Discretizer] Installing Discretizer | umassche | OpenFOAM Community Contributions | 26 | January 25, 2017 05:33 |
How to import a data file (excel,txt or csv)to Fluent or CFD-Post (the easiest one)? | silvai | FLUENT | 0 | January 5, 2015 09:22 |
[swak4Foam] Calculate statistics for a cellSet with swak4Foam | cnsidero | OpenFOAM Community Contributions | 12 | September 10, 2013 18:52 |
