Home > Forums > Visualization & Post-Processing Software > EnSight
Ensight data format
Old   January 22, 2004, 13:15
Default Ensight data format
Tim
I have written a finite difference code to simulate electromeagnetic field distribution. The scheme I have used involves fairly complex staggering of the solved variables - I have a number of variables at the cell centre, 3 variables on verticies and 3 variables on faces.
We have got an ensight license so I am trying to write output filters for my results - the cell centred variables are no problem but I dont see how to do the vertex and face based variables.
Are there any Ensight users who could advise me what to do
Tim
Old   January 23, 2004, 07:31
Default Re: Ensight data format
sylvain
You may look at your User Manuel, chapter 11. You can reach it with the help menu button on your Ensight interface. Variable can be declare as "per node" or "per_element".
Hope that Help,
Sylvain
Old   December 19, 2012, 13:30
MuratSuer is on a distinguished road
I hope I do not forget wrong but as I remember while to generating your result based on node location you have to define all direction for variables.
For example six direction should be defined for node based for EnSight case format
Velocity
TX TY TZ RX RY RZ
MuratSuer is offline   Reply With Quote
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 13:50
Best format for simulation data? cbisw Main CFD Forum 9 May 30, 2011 02:38
OpenFOAM native format data visualization and workflow zeliboba OpenFOAM Post-Processing 0 September 12, 2008 08:44
XYZ (ASCII format) data points into GAMBIT Neil FLUENT 1 August 7, 2007 09:24
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
