Interior-Wall in Numeca Hexpress/Hybrid
Hello!
I want to make an interior wall with Hexpress/Hybrid but I don't find the way. To make the case simple, let's say that I want to mesh just a pipe, with a filter in the middle that I want to simulate in Fluent as a Porous-jump boundary. All I have managed to do is two meshes and then make an interface in between... The thing is that I would like to be able to make the whole mesh in just one step, and if the surface is a Interior-Wall and I have a conformal mesh, much better... I tried doing a mesh with two starting points, but then the wall is just a wall, and I cannot change it into interior in Fluent... Thank you very much!! |
In the current release it is not possible to make it in one step with a conformal mesh. But this is planned for the release v4.1 later this year.
Zero-thickness interior walls
I am going to handle zero-thickness interior walls inside Numeca hexpress/hybrid. However I could not be able to do that. could you please someone help me in this regard?
Thanks in advance. |
