Blade Displacement_NLH Method
I've been trying to run FSI simulation of wind turbine blade based on modal approach using NLH method in FINE/Turbo. I have a question related to the blade displacement. I want the blade deformation to be 1 or 2% blade span. However, the solver couldn't run with those displacements, so I needed to reduce the deformation to 0.1% with which it solved successfully. If I want the deformation to be the larger value (up to 2% blade span), what would I need to do? Thank you very much in advance. |
