How to connect the radial diffuser grid(one channel) with volute grid in IGG |
February 8, 2023, 11:34 |
lihua
Dear everyone,
I'm working with a centrifugal compressor, the impeller and radial diffuser grid are generated by Autogrid5(only one channel), the volute grid is generated by GridPro,I want to merge these grids with IGG, could someone tell me how to set the boundary conditions of radial diffuser outlet block patch and the inlet block patch of the volute? thank you very much |
[Other] radial diffuser geometry generation problem | merouaneaero | ANSYS Meshing & Geometry | 0 | March 28, 2022 18:32 |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
Fine/Turbo cannot open grid built by IGG, Configuration file problem? | wkjshon | Fidelity CFD | 6 | March 29, 2016 02:09 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
