Home > Forums > Software User Forums > Fidelity CFD
Help regarding importing 2 element aerofoil and meshing.
Old   February 13, 2025, 15:56
Lightbulb Help regarding importing 2 element aerofoil and meshing.
Hamza Hussain
hop04 is on a distinguished road
Hey, I have two questions.
1) I understand that if I want to import aerofoil geometry into Pointwise, for a normal 1 element aerofoil, I would just import the ASCII coordinates from a website such as
http://airfoiltools.com/airfoil/deta...l=naca23012-il
However I am not sure what format the textfile must be?
2) I am trying to import the following 2 element aerofoil.
https://ibb.co/LhpkMpCg
It is a N.A.C.A. 23012 AIRFOIL WITH AN N.A.C.A. 23012 EXTERNAL-AIRFOIL FLAP.
How would I go about importing such a mesh in Pointwise Fidelity. Is there a way in Pointwise for me to import two aerofoils (in this case it would be importing the 23012 datafile twice) and then, by using some transform tool, I can translate, scale and rotate the flap. Is this possible? Or is there a way to produce this aerofoil in some software and get its coordinates.
3) I will be analysing the lift of this foil, would it be best to use an extrusion-normal O-type topology? That seems simplest.
hop04 is offline   Reply With Quote
Old   February 16, 2025, 23:34
Default Please help
Hamza Hussain
Anyone? I really need help with this
aerofoil, airfoil 2d, mesh 2d, pointwise mesh
2D aerofoil meshing (sharp trailing edge) How to avoid high aspect ratio pchoopanya Mesh Generation & Pre-Processing 2 July 18, 2018 05:24
[ANSYS Meshing] problem in meshing of Aerofoil shaped obstacles in plane channel. lohith ANSYS Meshing & Geometry 0 June 20, 2018 02:58
[Other] Meshing Layers over Aerofoil poloding-along OpenFOAM Meshing & Mesh Conversion 5 April 4, 2014 10:41
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 01:59
Meshing an aerofoil with a plain flap Fatou FLUENT 0 November 15, 2005 14:24
