run time
Hello everybody,
can Numeca give an estimation about the run time? thank you Cenzo |
it is impossible for NUMECA to give such estimations.
it needs exprrience and can be only done by user approximately. in fact it depends many parameters like: -mesh type (sturctures, unstructured) -mesh sizes -flow field geometry (shape and dimensions) -flow regime (laminar or turbulent) -near wall treatment method applied -turbulence model used (if any) -initial conditions -convergency criteria -time dependency of flow (steady or unsteady) -subsonic or suppersonic flow? -single or multi phase flow? each of parameters named above can affect run time. Regards |
Thank you!
