March 29, 2011, 04:37 |
FieldView question
Kiran
Hey. I am considering using the FieldView (FV) postprocessor to analyze my CFD results. However, I am not sure if FV can import the output files from my solver (DYTRAN by MSC software). Does anyone know if FV can read .arc files?
March 29, 2011, 06:41 |
#2 | |
Raashid Baig
You can try free post-processor ParaView http://paraview.org/ See the list of reader available in ParaView at http://paraview.org/Wiki/ParaViewUse...ist_of_readers Raashid Baig |
March 29, 2011, 08:13 |
Kiran
Hi Rashid,
thanks for your response and for the tip on Paraview. I will double check what file formats I can export and see if I can find a format that is compatible with Paraview. If that doesn's work then I will try to explore the Fieldview approach again. Thanks Kiran |
August 15, 2012, 13:45 |
EnSight can read Dytran data, has for 10 years
Darin McKinnis
I used to work at MSC for the Dytran group, so I would know.
Reads the .ARC and .THS files. |
fieldview fv arc |
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 16:03 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
For Fluent and FieldView users | Germain Lannegrand | FLUENT | 0 | March 27, 2001 07:28 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
Fieldview Data Format?? | Choong K. Yoo | FieldView | 0 | August 23, 1999 19:59 |
