August 20, 2012, 06:57 |
Convert flow to rpm
Dear colleagues,
We currently need to calibrate a flowsensor (turbine) like the one on the screenshot below. As it takes a lot of effort to calibrate this flowmeter in practice we would like to calibrate it by using Floworks. By calibrating I mean finding which rpm corresponds with which flow rate. Can someone tell me: 1. Is this possible by using Floworks? (I mean deriving a rotation frequency by applying a certain volume flow rate) 2. Can someone give me some help in setting up this model. Thank you very much in advance, Kind regards, Peter Zwart |
September 1, 2012, 09:50 |
To do what you are asking takes the ability to move the blades with the fluid, which cannot be done with SW Flow Sim.
What you can do is find the relationship (by a curve) between pressure drop and flowrate for a given fan speed since you have to define the blade rotational speed in FS. |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 01:22 |
transient, impregnating flow problem | fgommer | FLUENT | 0 | February 29, 2012 16:10 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
