I want to confirm the performance of the axial flow fan. |
October 14, 2013, 20:57 |
Korean Pie
CFD calculation reference conditions of the axial fan. Air, 20 [˚c] - 1.2 [kg/m^3] Mass Flow = 16 [kg/s] Static Pressure = 540 [Pa] RPM = 1180 rpm = 123.569311 [rad/s] ------------Ansys--------------- In the case of Ansys Cfx program, Inlet Lid = Total pressure - 0 [pa] Outlet Lid = Mass Flow - 16 [kg/s] ------------Ansys--------------- ------------Floworks--------------- However, in the case of a program of Floworks, Inlet Lid = Mass Flow - 16 [kg/s] Out Lid = Static Pressure - 540 [Pa] ------------Floworks--------------- Ansys program, satisfied with the results. Floworks program are dissatisfied with the result. Floworks conditions set, Is my mistake? To answer please. |
October 29, 2013, 04:22 |
Disabled
Rep Power: 23 |
I'm not quite sure I understood you correctly.
Is that the fan data in the engineering database? I hope there is more data of the mass flow rate for the fan to have a real fan curve that is depending on the pressure difference between the inlet and outlet of the fan. At the moment you have 16kg/s constant with some swirl, at least from what you wrote. Also are you sure it is 540Pa? Is this a vacuum pump or a default fan such as for electronics cooling? Other than that I cannot help you as there is too little information on what it not working right or what the error is that you see. Regards, Boris |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
reg-Classical method of axial fan design | ramamoorthyramanan | Main CFD Forum | 0 | June 25, 2010 01:45 |
urgent pressure condition for axial flow fan | VIPUL | FLUENT | 0 | October 24, 2008 03:01 |
How to model flow of centrifugal fan? | Peter | Main CFD Forum | 0 | April 2, 2008 07:07 |
