Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Solidworks flow - Basic FAQ
Old   April 29, 2014, 18:07
Default Solidworks flow - Basic FAQ
victoryv is on a distinguished road
I have recently joined a new company where people just started to use solidworks flow for CFD analysis . I haven't' used it yet. I don't know how good it is, but I have some questions.
1. People here were obtaining results without even doing mesh independent study. I was startled. Does solidworks take care of mesh itself?
2. Do we have greater control over mesh ? Can we create boundary layers?
Can we create local meshes?
3. How good are the results?
victoryv is offline   Reply With Quote
Old   May 6, 2014, 10:26
Disabled
Boris_M will become famous soon enough
Hi Victoryv,
Congratulation to become a FS or EFD user ;-)
1. Kind of... usually we suggest to do some mesh studies in order to get some experience in the beginning when starting to use the software. There are some rule of thumbs such as at least 3 cells over a small gap in which you have some important flow, you don't have to resolve all small gaps with that rule where there might be some weak secondary flow but more the more important gaps. If you want high accuracy you should resolve a nozzle for example with ~8-10 cells etc.
There is some meshing and solver technology that resolves some of the typical issues you spend days on mesh convergent studies for certain mesh regions.
2. Yes, you can create local meshes and go into more detail of the mesh settings than automatic setting Level x. But why do you need boundary mesh if the solver handles it for you. If your mesh is too coars for the boundary layer is not resolved with the mesh so we apply automatically a boundary layer apprach which you can find in the documentation and if the mesh resolves the boundary layer the boundary layer is calculated by the solver directly.
You have to consider to think different compared to the typical CFD tools.
3. That really depends on the application you are trying to calculate as with every solver. Some are ideal for turbomachineries but not so good as others for external aerodynamics etc. What are you applications?
Regards,
Boris
Boris_M is offline   Reply With Quote
Old   May 6, 2014, 18:54
Thank for the info Boris. Here people are using it for more design optimization. Let me play with the software more. If it is able to handle mesh and boundary layers itself then that is great.
Originally Posted by Boris_M View Post
Hi Victoryv,
Regards,
Boris
Ball valve flow in solidworks nikesh FloEFD, FloWorks & FloTHERM 10 December 10, 2013 08:40
Problem, solidworks flow simulation castaway FloEFD, FloWorks & FloTHERM 3 September 11, 2012 12:44
problem with result, SolidWorks Flow simulation CCC FloEFD, FloWorks & FloTHERM 7 June 14, 2012 00:19
flow simulation on airfoil using solidworks ravivmis Main CFD Forum 0 April 8, 2012 11:40
Appropriate flow velocity for basic 2d analysis Lukasz Mosakowski FLUENT 1 February 14, 2006 08:58
