Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Heat generation rate in SolidWorks Flow Simulation
Old   April 15, 2016, 03:07
Default Heat generation rate in SolidWorks Flow Simulation
smp
Satish
smp is on a distinguished road
Suppose if bulb filament is being supplied with 10W, out of which 3W is used to light the bulb and remaining 7W is dissipated as heat, then is it 7W of "Heat Generation Rate" to be applied in SolidWorks Flow Simulation?
How is the heat generation/dissipation rate calculated from total wattage supplied?
smp is offline   Reply With Quote
Old   August 16, 2016, 05:31
Disabled
Boris_M will become famous soon enough
Hi SMP,
sorry for the late reply, I haven't been able to look after the questions for some time.
If we are talking about a regular incandescent bulb, then 3W out of 10W would be 30% efficiency and that is not realistic for a bulb. We are talking more about 7% efficiency for bulbs.
So correct would be a 93% for the heat generation rate.
The radiation portion and the convection and conduction portions are of course then depending on the properties of the simulation such as radiation properties of the surface, air flow that cools the filament and the conduction into the socket. There will be a balance between all these heat transfer methods that FloEFD iterated to depending on these properties.
After all CFD is an iterative approach.
You can measure the portions via the goals on the components to see how much is radiation, convection and conduction.
I hope this helps.
Boris_M is offline   Reply With Quote
Old   November 21, 2016, 03:23
Default Thanks Boris
smp
Satish
Thanks for your explanation.
freelancer/pay:Coding solidworks flow simulation API using microsoft visual studio Edreez CFD Freelancers 1 December 8, 2015 11:18
DPM total mass flow rate yow FLUENT 0 July 17, 2015 12:01
How to Define heat generation rate that changes with the system coordinate. a19910112a OpenFOAM Running, Solving & CFD 2 December 12, 2014 03:22
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 16:06
Heat Generation rate in W/m³ ashghan OpenFOAM Programming & Development 0 June 27, 2014 05:42
