Solidworks Flow Simulation crashed when viewing results |
November 28, 2014, 18:01 |
John Bulzacchelli
Rep Power: 11 |
I'm hoping someone can help me with an issue I am having in Flow Simulation. I can solve my simulation, but when I go to view results Solidworks instantly crashes. This happens most often when I try to view a cut-plot. I ran Solidworks Rx and found no issues, and am currently repairing my SW install. Is there a way to generate a crash report to see what is causing the issue? Here are my system details: SW2014 SP2 Windows 8.1 ASUS Q550LF Laptop Quad-core i7 4700U (1.8GHz) 8GB RAM NVIDIA GT 745M GPU (1GB) Any help appreciated! John |
November 29, 2014, 05:24 |
John Bulzacchelli
Rep Power: 11 |
I finished re-installing SW and this did not solve the problem.
I am open to ideas. John |
December 10, 2014, 03:46 |
Windows log
Rep Power: 11 |
Have you checked the "windows log" through Event viewer ?
December 24, 2014, 09:08 |
Sascha
Rep Power: 11 |
Change your grafic gard to a quadro or Firegl and it will work // sorry you have a Laptop.
best wishes Sascha here is the link certified Card for solidworks http://www.solidworks.com/sw/support...rdtesting.html |
January 14, 2015, 08:20 |
Disabled
Rep Power: 23 |
Usually might be related to the graphics card but you should first try to update your drivers as there might have been some updates in the visualization that requires a newer version of some drivers such as OpenGL or something else.
If that doesn't help try if you can show another plot such as surface or trajectories. Boris |
October 11, 2016, 04:49 |
Rita Szijarto
Rep Power: 12 |
You should go to Systemoptions --> Performance --> Check Use OpenGL
This should fix the issue with the crashing cut plot. Be aware that some functionalities of the software will be affected, e.g. if you want to save an animation, you have to check this option out, otherwise you will get black screen only. |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Wind Tunnel Flow Simulation Mass Flow BC Issue | ledelman | SU2 | 4 | August 3, 2014 18:38 |
Reliablity of SOLIDWORKS FLOW SIMULATION... | addy01 | Main CFD Forum | 1 | March 6, 2013 12:12 |
flow simulation on airfoil using solidworks | ravivmis | Main CFD Forum | 0 | April 8, 2012 11:40 |
exemple of simulation results in reactive flow | GACEM_hatem | Phoenics | 0 | June 6, 2001 14:13 |
