Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Gap
Old   August 12, 2017, 11:28
Default Gap
Averome is on a distinguished road
Hello everybody. I want to calculate the flow of air through the gap. Air enters the gap at a pressure of 4.7 MPa, within the gap pressure 1.47 MPa. Weight consumption 8 kg / s.
I collide with the fact that I can not get the pressure at the output of 1.47 MPa. What can I do wrong? How to be when solving such problems? The disk is solved by a sector of 90 degrees. In the initial conditions I set the pressure at the inlet of 4.7 MPa, the temperature of 200 k at the outlet is the static pressure 1.47 MPa
I carry out a calculation check on the density of the medium, but here the variable pressure is the channels in which the velocity increases. Thank you
Sent from my MI 4W using CFD Online Forum mobile app
Averome is offline   Reply With Quote
Old   August 12, 2017, 12:27
Old   August 14, 2017, 02:04
Initial conditions .: 101325 pa, 200k. Input 8kg / s, thermodynamic parameters at the inlet 4.7 MPa temperature 200k. Output: static pressure 1.47 MPa, temperature 200k. Correct me if I do not specify parameters. Thank you
Old   August 14, 2017, 02:19
Picture solver
Old   August 16, 2017, 09:33
Disabled
Boris_M will become famous soon enough
I have no idea what you are trying to solve, where the inlet boundary condition is defined and where the outlet boundary condition.
I also did not understand what your problem is. I'm sorry.
If you are using FloEFD I would recommend contacting support and someone can help you directly. If you use SWFS, then please contact also your local support team.
Regards,
Boris
Boris_M is offline   Reply With Quote
Old   August 16, 2017, 13:01
Regards,
Boris
Hello, Boris! thanks for the answer. I try to blow air into the gap between the disc and the lid, not even this is the most important question, my question is how to be when the air enters, say in an elongated cylinder from the end, at a pressure of 4,7 MPa, and at the output the boundary condition is the static pressure of 1, 47 MPa, what should the initial conditions be in this case?
Thanks you
Old   August 17, 2017, 09:58
I write on which option stopped at the choice of the initial conditions. Initial pressure 4.7 MPa temperature 200k. Thermodynamic parameters at the inlet pressure 4.7 MPa, temperature 200, mass flow 8 kg / s. The boundary condition at the outlet is a static pressure of 1.47 MPa. The calculation turned out to be physically correct. thanks to all
Rotor Stator air gap of an electrical machine dracula-007 CFX 14 August 23, 2022 04:44
[Technical] Filling tha GAP between two meshes GregSpy OpenFOAM Meshing & Mesh Conversion 0 December 14, 2015 09:52
Heat transfer through gap in CFX? shivasluzz CFX 4 September 3, 2014 12:32
[snappyHexMesh] Meshing a small gap between walls staustrahltriebwerk OpenFOAM Meshing & Mesh Conversion 1 July 23, 2012 11:46
ICEMCFD - Prisms in a gap Andreas CFX 1 January 18, 2009 18:24
