Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Defining two ambient temperatures in FlothermXT
Old   April 26, 2018, 17:23
Default Defining two ambient temperatures in FlothermXT
Pablo Joaquim
pablojoaquim is on a distinguished road
Hi everyone! This is my first post in the forum!
I'm Systems Engineer in a company located in Argentina. We develop and manufacture automotive products, and now I'm working in determining the power dissipation of one of our products.
We always work with a unique ambient temperature, but now our customer is asking us about performing a simulation with two ambients.
The product is located in such a way that the backend (the chassis which works as the heatsink) is inside the automotive dash pannel (70ºC), while the frontend (plastic ABS and some circuitry) is in the habitacle temperature domain (35ºC).
Anyone could help me in how to define this condition in FlothermXT? I couldn't find an easy way to do this...
pablojoaquim is offline   Reply With Quote
Old   January 7, 2019, 23:20
Smile
DB
DB99 is on a distinguished road
Use a two fluid model as if it were a heat exchanger, and copy Air material to Air2 material using one material on either side.
Use Pressure boundary "lid" to either side. FloTHERM XT can apply pressure boundary but not provide gravity gradient so the pressure on that boundary will not vary with elevation. Can cause problems in resultant flow field if using natural convection.
simple brute force method: make makeshift inlet manifold with surface surrounding it at constant temp. If manifold is long enough the outlet air of the manifold (inlet air to your model), inlet to either side of your dashboard, will be at the prescribed surface temp.
DB99 is offline   Reply With Quote
ambient temperature, flotherm, flothermxt
How to calculate node temperatures from cell temperatures? h0rst FLUENT 2 May 28, 2017 00:15
Wall temperatures FUDM FLOW-3D 0 November 27, 2015 14:00
Solar load model and ambient temperature itsme_kit FLUENT 0 January 31, 2014 18:18
Probelm with supersonic exhaust to ambient newj CFX 2 August 9, 2012 18:01
Reaching too high Temperatures using turbulentHeatFluxTemperature BC Wokl OpenFOAM Running, Solving & CFD 0 March 28, 2012 09:19
