Using the fluid volume without the structural parts |
TW
Rep Power: 7 ![]() |
Hey,
FloeFD is still confusing me sometimes. As a geometry input i have the fluid volume. FloeFD prompt me to at some lids for making the volume waterproof. But it didnt worked. How can I work with the fluid volume? Best regars |
Disabled
Rep Power: 24 ![]() |
Hi TW,
no, FLOEFD is for designers and designers usually don't design the fluid volume but the actual positive model. So no need to extract the fluid volume, you can work with the positive. It helps much better to understand the model than working on the inverted (negative) model. If you don't have a positive model, you should subtract the fluid model from a block. The lids are necessary to make a positive part watertight. FLOEFD then automatically recognizes the interior fluid volume as the empty space. Regards, Boris |
TW
It resolves my confusion.
Many thanks. |
Display Modes | |
Controlling fluid volume fraction over time at the inlet of a pipe | Gwench | Fluent Multiphase | 1 | December 9, 2015 08:59 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
fluid hot volume in fluid cold volume | zahid | FLUENT | 4 | June 1, 2002 09:11 |
