FloEFD 17.0 error : A File System error occurred : Not Enough Disck space Left
1 Attachment(s)
Hi All,
Vivek here. I am new to this forum, Recently I am facing with the following issue when I open Flo-EFD17.0 Project File. Could some one Pl. read the problem and share your thoughts over it. Thanks ! FloEFD (SW) 17.0 Sequence : Open FloEFD --> Load previous project --> Error pop up "A File System error occurred : Not Enough Disk space Left" --> Click Ok -->FloEFD Opens with only Components inside the Assembly but don't see projects Sometimes (rarely) this error goes away after I restart the PC /use C Cleaner and open the project. I have tried re-installing FlOEFD17.0 and create a new project but still this error continues in our computers ( Windows 7 & 10) Attached : FloEFD Error Pic |
Hi Vivek,
I've never seen this issue and have no idea what the reason for this might be. If you experience it on different computers, I would suggest to send it to the Support, they will likely want to see the model as well to test if they can reproduce it on their computers as well. Regards, Boris |
