Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Air with water analysis
Old   March 27, 2020, 14:09
Default Air with water analysis
Amir s
amirs is on a distinguished road
I have a tank with inlet and outlet port . the inlet port is higher than the oulet
i want to know if its possible to make a time dependent analysis.
the original test that i want to simulate is:
the initial condition is that the tank is full with air.
at the beginning i fill water through the inlet port and after the water go above the oulet port i switch on a pump that keep the level of the water steady just above the outlet port.
attached a file with the setup
can i use floefd to simulate this test
Regards
amirs is offline   Reply With Quote
Old   April 3, 2020, 15:34
Default Yes, for FloEFD v17 and higher
Joe Galliera
flowjoe is on a distinguished road
Send a message via Skype™ to flowjoe
Yes, you can simulate this free surface flow scenario in FloEFD v17 and higher.
flowjoe is offline   Reply With Quote
Water Sphere reacting to flow of air modelling Jacee FLUENT 0 May 25, 2018 09:29
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Mass Transfer Between AIR and WATER Math13570 CFX 12 June 29, 2016 08:14
3D multiphase micro model: mixing effect of air and water at the T junction ehsanfareed FLUENT 2 March 22, 2015 22:29
Is it possible to integrate air through a system with mixture of air and water? Hale OpenFOAM Post-Processing 1 September 30, 2013 08:57
