Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Axial Periodicity in Floefd
Old   May 12, 2020, 10:45
Default Axial Periodicity in Floefd
francesca gave
fra gavel is on a distinguished road
Hello
I have to study the heath path in the model in Figure 1.
In this model the grey and the orange component are heat volumetric sources.
The problem is that I would like that the heat coming out of one face to be the heat going inside another face (Figure 2); basically, the boundary conditions of one face are the properties of the other face, but those two faces are not conincident (Figure 3).
I tried to use Axial Periodicity, but the results aren't good.
Is there another way?
Thank you very much
fra gavel is offline   Reply With Quote
Old   May 22, 2020, 08:00
Disabled
Boris_M will become famous soon enough
Hello Francesca,
Have you tried a goal dependency where you place a goal on the one side asking for the heat and link the heat source of the other side with that goal?
Also a reason for the axial periodicity might be that the model is cut already and it works much better if the model is in full scale or at least somewhat bigger than the actual computational domain/wedge of the axial periodicity. Otherwise it is numerically not ideal defined with a surface ending the model directly at the symmetry plane.
I hope this helps,
Boris
Boris_M is offline   Reply With Quote
Old   May 23, 2020, 09:34
francesca gave
Hi Boris,
Thank you for your suggestions, I will try both ways
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
FloEFD for axial and radial blower CmdrFALCO FloEFD, FloWorks & FloTHERM 3 September 9, 2015 02:31
How to calcualte Axial flux of angular momentum and Axial flux of axial momentum ? nanavati OpenFOAM Running, Solving & CFD 0 November 21, 2014 09:47
[ICEM] Two kinds of periodicity in one project PS_KA ANSYS Meshing & Geometry 3 January 22, 2014 04:09
Periodicity momentum instead of axial momentum omez CFX 1 August 3, 2009 18:59
