Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Fan Operating Point Error
Old   January 12, 2021, 05:57
Question Fan Operating Point Error
ulas
UlasB is on a distinguished road
I'm using FloEFD™ 2020.2,
My project has 5 fans and fan model is manually created by defining Fan Curve.
I used enough data (12points) for curve. I think its enough.
Anyway, here is my question.
When I got my results, I clicked "Show Operating Point" on Fan to see fan operating curve. However it gave me a following error:
"Can not create chart with these results. Please, recalculate it."
What is possible mistakes that I've done.
This is the error massage and my fan curve;
UlasB is offline   Reply With Quote
Old   January 19, 2021, 04:25
Disabled
Boris_M will become famous soon enough
Can you check what the flow rate and pressure difference are manually for this fan?
Simply use the surface parameter on the inlet and outlet side of the fan depending on the fan type you used (internal, external inlet or external outlet).
For the external ones, you have specified a pressure in the BC itself. That's the one on the outside of the model and the difference is then only used to the calculated inside pressure at the fan surface.
Make sure you use the right pressure for the surface parameter when calculating the difference.
Was there any other error message during the solver run in the solver monitor area for the errors?
For example, if the BC of the fan was for some reason invalid, it might not have any values of the fan curve, hence the error.
Boris
Boris_M is offline   Reply With Quote
#fan, #floefd, #operatingpoint
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
