Increase in fluid mass during rotation
Hello everybody!
I am trying to solve a task of mixing molten aluminum in a container. The problem uses free surface, sliding, and gravity. I stumbled upon a problem: over time, the mass of aluminum in the container increases and its level also rises. I can't understand why this happens. Maybe I set something wrong when I was setting the task? Has anyone come across this? https://yadi.sk/i/yCMLdxeXtHVisw |
Hi CFDnewbee,
Do you use any molten aluminum inlet in your project? Can you send a screenshot of your project tree? Regards, Evren |
The problem was in the incorrect setting of the rotating area. Its boundaries intersected with a rotating object and an error was formed. Thank you! |
