Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Solidworks Flow simulation - Turbulence intensity and length scale
Old   January 21, 2025, 11:06
Default Solidworks Flow simulation - Turbulence intensity and length scale
Anonym
WalterFurst is on a distinguished road
I have recently started my job after graduation and I have started to work with Solidworks Flow Simulation. I am searching help with definition of turbulence properties - turbulence intensity and length scale.
1) Turbulence intensity of small fans for air-cooling of electronics components in devices. I tried to find some approximate values of turbulence intensity for fans but unsuccessfully.
2) Turbulent length scale:
In case of pipe flow, I am not sure whether I should use l=0.038*L or l=0.07*L as stated here: https://www.cfd-online.com/Wiki/Turbulence_length_scale
In a general case, where on the inlet is perforated plate, or the inlets are small openings in device cover, what could be good approximation for l ?
Thanks in advance for suggestions and information.
WalterFurst is offline   Reply With Quote
solidworks flow, turbulence intensity, turbulence length scale
CFX turbulence intensity, turbulence length scale, Turbulence Eddy Dissipation harrydu CFX 5 December 16, 2020 06:33
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
Estimation of turbulence length scale J.Y.Won OpenFOAM Pre-Processing 0 April 28, 2015 08:16
specify the turbulence intensity and the turbulence length bennoman75 Main CFD Forum 0 May 15, 2013 06:36
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
