Joey Zhang
Rep Power: 0 ![]() |
I created a flow domain in CATIA (a volume in a part) and need to run FloEFD. However, FloEFD treats the CATIA volume as a solid by default. How should I set up the case to assign the volume as fluid?
Praharsha Reddy
Rep Power: 7 ![]() |
Usually FloEFD works with solid body.
Eg: if you have a solid volume all you have to do is create lids for inlet and outlet. Then you can check for fluid domain using check geometry option. i found this tutorial on youtube Tutorial: https://www.youtube.com/watch?v=PlxF6U5HIdc |
#3 | |
Joey Zhang
Thank you for the reply.
I just want to simulate a fluid-only case because the solids significantly cost computation resource. The dilemma is my fluid domain was generated by many solids. My simulation involves heat transfer, but the solids bounding the fluid are not important for heat. I only need them in generating the fluid volume but do not need them in my thermal simulation. Do you have any suggestion? Quote:
Display Modes | |
API for FloEFD 15 (Pre-processing, Solving, Post-processing) | fung | FloEFD, FloWorks & FloTHERM | 13 | September 2, 2023 02:00 |
Flotherm vs Flotherm XT vs FloEFD | zdunol | FloEFD, FloWorks & FloTHERM | 39 | July 14, 2020 08:36 |
FloEFD Standalone --> FloEFD NX Embedded | weberli | FloEFD, FloWorks & FloTHERM | 1 | March 6, 2020 06:34 |
FloEFD vs. Ansys Fluent | engineerm | Main CFD Forum | 0 | October 2, 2019 04:30 |
FloEFD for axial and radial blower | CmdrFALCO | FloEFD, FloWorks & FloTHERM | 3 | September 9, 2015 02:31 |
