Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Wall Roughness
Old   April 27, 2008, 18:40
Default Wall Roughness
LKF
Has anybody had luck (or attempted) to simulate very rough walls in FLOWORKS? I'm currently trying to validate textbook calculations for Rz values in the order of 1E6 - 1E9 micro-inch and I am not getting results that correlate whatsoever.
Thanks for the insight/opinions.
Old   April 27, 2008, 19:20
Default Re: Wall Roughness
LKF
Sorry, typo on the Rz values. I'm only looking at values up to about 3E6 micro-inch. Not 1E9!
Old   April 28, 2008, 07:26
John Parry
3E6 micro-inch is 3 inches. Can you elaborate on the application? How thick is the boundary layer?
John Parry, Research Manager, Flomerics Ltd.
Old   April 28, 2008, 08:06
LKF
Hello, thanks for the reply. Yes, 3E6 is 3 inches. Is this within the limits of the calculation scheme used by FLOWORKS to calculate wall shear stress and the resultant pressure drop along a flow domain?
The application I'm trying to model is loosely based on ambient airflow through mine shafts with shotcrete finished walls or just blasted/bored. It's large scale models (15 to 30 foot diameters) - I would anticipate bl thickness in the order of 6 inches to perhaps 18 inches. What scheme does FW use for bl approximation?
Additionally, where can I review the residual values after the calculations have finished iterating? The word 'residual' doesn't even show up in the FW help files when I search for it.
Thanks for the assistance,
Old   April 28, 2008, 10:49
LKF
I've continued to look into wall roughness effects. Not only are my results not lining up hand calcs, pressure drop along a 800 ft section (with fully developed flow) is not even varying for different Rz values.
Old   May 8, 2008, 10:22
Kelly Cordell-Morris
Do you have access to the validation examples in Floworks? In EFD Lab one of the validation examples is flow over smooth and rough plates. I have just quickly changed the parameters of one of these models and obtained a pressure drop profile. What parameters are you using to check for convergence? The drag coefficent would perhaps be one to use? Cd = F / ((0.5*rho*V^2)*A))
F=drag force, A=surface area, rho=fluid density, V=fluid velocity
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Roughness Height of a wall Vijay FLUENT 0 December 17, 2009 15:13
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Wall Roughness Error Ken FLUENT 1 April 23, 2007 12:59
