April 27, 2008, 18:40 |
Wall Roughness
Has anybody had luck (or attempted) to simulate very rough walls in FLOWORKS? I'm currently trying to validate textbook calculations for Rz values in the order of 1E6 - 1E9 micro-inch and I am not getting results that correlate whatsoever.
Thanks for the insight/opinions. |
April 27, 2008, 19:20 |
Re: Wall Roughness
Sorry, typo on the Rz values. I'm only looking at values up to about 3E6 micro-inch. Not 1E9!
April 28, 2008, 07:26 |
Re: Wall Roughness
3E6 micro-inch is 3 inches. Can you elaborate on the application? How thick is the boundary layer?
John Parry, Research Manager, Flomerics Ltd. |
April 28, 2008, 08:06 |
Re: Wall Roughness
Hello, thanks for the reply. Yes, 3E6 is 3 inches. Is this within the limits of the calculation scheme used by FLOWORKS to calculate wall shear stress and the resultant pressure drop along a flow domain?
The application I'm trying to model is loosely based on ambient airflow through mine shafts with shotcrete finished walls or just blasted/bored. It's large scale models (15 to 30 foot diameters) - I would anticipate bl thickness in the order of 6 inches to perhaps 18 inches. What scheme does FW use for bl approximation? Additionally, where can I review the residual values after the calculations have finished iterating? The word 'residual' doesn't even show up in the FW help files when I search for it. Thanks for the assistance, |
April 28, 2008, 10:49 |
Re: Wall Roughness
I've continued to look into wall roughness effects. Not only are my results not lining up hand calcs, pressure drop along a 800 ft section (with fully developed flow) is not even varying for different Rz values.
May 8, 2008, 10:22 |
Re: Wall Roughness
Do you have access to the validation examples in Floworks? In EFD Lab one of the validation examples is flow over smooth and rough plates. I have just quickly changed the parameters of one of these models and obtained a pressure drop profile. What parameters are you using to check for convergence? The drag coefficent would perhaps be one to use? Cd = F / ((0.5*rho*V^2)*A))
F=drag force, A=surface area, rho=fluid density, V=fluid velocity |
Laminar flow and wall roughness | junbbung | FLUENT | 2 | November 26, 2022 21:22 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Roughness Height of a wall | Vijay | FLUENT | 0 | December 17, 2009 15:13 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Wall Roughness Error | Ken | FLUENT | 1 | April 23, 2007 12:59 |
