April 18, 2009, 00:22 |
pump's flow simulation
dear all,
I was attempting to create a flow simulation for a pump but not really sure is the setting right or not. my goal was to obtain the pressure different. Do comments. Below is the setting: > inlet define as 0 m^3/s > outlet define as static pressure > using local rotating region where the local region is disable & define with certain RPM. final result i get -ve pressure at 1 side, is this correct? For the pressure different, i have to add both or minus? Thx!~ |
April 20, 2009, 02:41 |
Ivan Dergunov
Hi, in the case of your statement negative pressure shows, that the cavitation flow is presented. You should turn cavitation option on to obtain the solution.
General Settings>Fluid> and find the cavitation checkbox here
8 Year in CFD |
April 20, 2009, 10:23 |
i see. Is it also related to my meshing setup as well? is there anything that i need to take note on the mesh side?
thx!~ |
Channel flow setup in Large-eddy simulation | Weihua | Main CFD Forum | 6 | November 17, 2015 09:33 |
Incompressible to compressible flow simulation | Nishikant Tamrakar | FLUENT | 10 | June 16, 2009 21:09 |
Compressible Flow Simulation - business jet | Tyler | FLUENT | 0 | March 13, 2009 14:47 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
simulation of three dimensional flow in turbine | md nizee | Main CFD Forum | 2 | December 6, 2000 02:08 |
