Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Non-uniform heat transfer coefficient in Flotherm
Old   June 25, 2009, 21:01
Default Non-uniform heat transfer coefficient in Flotherm
Melvin.
bighead is on a distinguished road
Hi all, just wanna know if its possible to have a non-uniform heat transfer coefficient in Flotherm ?
bighead is offline   Reply With Quote
Old   June 26, 2009, 07:39
Robin Bornoff
RobinB is on a distinguished road
Non-uniform is space? Not directly no. A series of HTC can be defined via a number of cutout objects that externally abut the solution domain. These can be defined manually or be created automatically from another model when you use the 'Zoom-in' functionality.
RobinB is offline   Reply With Quote
Old   June 26, 2009, 15:39
Melvin.
I tried the first option and it work generally fine, except for the postprocessing whereby the cutouts had temperatures of the ambient/global. When I posted the question, I was thinking more of writing a general function of HTC=f(x,y) at the low z. But since the first option solved the problem, I shall lived with it. Thxs for your help Robin.
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
heat transfer coefficient Jorge Facao FLUENT 0 June 4, 2004 16:35
